WOW loud whine?
Old Feb 9, 2010 | 03:45 PM
fastcam91's Avatar
WOW loud whine?
Ok i just purchased this car and im trying to get it on the road. I posted a video of me shifting 1-4th gear. Not going much faster and you can hear how it gets significantly louder. I just want to know if u guys know what the problem could be before i start disassembling the rear.
http://s329.photobucket.com/albums/l...royah006-1.flv
Old Feb 11, 2010 | 01:14 AM
mrownage426's Avatar
Sounds like differential bearings. Since there is no clunk the ring and pinion should be fine.
Old Feb 11, 2010 | 12:47 PM
fastcam91's Avatar
if i was to change the differential bearing, would i have to take out the ring and pinion out?
Old Mar 3, 2010 | 11:05 PM
fastcam91's Avatar
ok since i dont have a lot of cash right now, i unbolted the caps on the diff and unbolted the driveshaft. I also took out the axles. When i spin the pinion it isnt as smooth as it was before. I believe it could be the pinion bearing and if i replace all of the bearings and crush sleeve could i just bolt it back up resetting the backlash?
Sooo would i need new shims at all and the ring and pinion should be fine correct? I saw no chips or anything on either.
Im gonna order my parts soon so i need to know what would be best to do and where is the cheapest.
Old Mar 7, 2010 | 10:47 PM
fastcam91's Avatar
Anyone at all?
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
cristian1311
Sep 12, 2015 08:16 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
Latronaxe
Jul 17, 2015 11:55 AM
