messed up the rearend?
Old Mar 8, 2010 | 12:38 AM
fastlt1camaro's Avatar
Ok I took out my carrier and put it in a different rearend because the other one was bent. I had to shim it but i think I did it wrong because when I go down the road the is a noise that get louder as I go faster. Does anybody know how much does it cost to have a shop shim it for me? Thanks for the help
Old Mar 8, 2010 | 04:10 AM
fastcam91's Avatar
That is the problem i have with mine right now. I think its my pinion and the guy that prev had it took it to a unreputable shop and they didnt put the nut on correctly. Good luck getting any help on this forum though, I have had my question up for weeks and I even put up videos and pictures to help. try LTXTECH.com
Old Mar 8, 2010 | 05:32 AM
You might want to limit the miles you put on it. You run the risk of wearing an incorrect contact pattern into the gear surfaces, and once you do that, it may impossibe to quiet them down, even if you get them set up right.
Did you change both the ring and pinion? Did you set the pinion depth correctly, and verify backlash?
Rittmeister
Aug 7, 2015 01:13 AM
88IROC_Z
Jul 22, 2015 11:38 PM
Boss002
Jul 9, 2015 03:33 PM
mrwz28
Jul 8, 2015 09:11 PM
