Wont go in gear...
Old Jun 8, 2009 | 08:44 AM
mrpittbull's Avatar
Wont go in gear...
Ok I did a couple of burnouts in my car...on the way home the car started gettin hard to go in gear. We made it home but now the thing wont go in gear at all with the motor running. It will with it off. WTF?...The motor , clutch is all new. Probly about 1500 miles. That clutch shouldnt go out after 2 small burnouts. Its a ram suregrip. Any ideas? Thanks
Old Jun 8, 2009 | 07:16 PM
johnny6's Avatar
If it won't go in gear with the engine running you have a slave cylinder or throwout bearing problem. You posted this in the wrong section.
Old Jun 10, 2009 | 08:06 AM
AL SS590 M6's Avatar
Moderator
yep it won't go into gear because the clutch isn't disengaging. Generally due to air in the system, bad master, bad slave.
And this is the wrong forum for drivetrain questions. Moving it.
Old Jun 12, 2009 | 09:53 PM
mrpittbull's Avatar
clutch
Well the master was changed and it still didnt work. Pulled the trans and the clutch had started coming apart. Pieces of it had got int the splines and wouldnt let the clutch disengage. Now this is a RAM suregrip clutch. I cant believe it did this. so now i have to get another clutch. Any suggestions? I do know its not goin to be another ram.
Lilatlboy6969
Aug 29, 2012 07:26 PM
NewbieWar
Mar 27, 2012 10:59 AM
95 Civic
May 7, 2008 11:35 PM
hallbilly
15
Oct 6, 2007 02:29 PM
Heatmaker
Mar 13, 2005 04:50 PM
