Will a 153 tooth flexplate bolt to a high performance torque converter?
Old Jun 29, 2008 | 09:26 AM
silver95's Avatar
What the title asks? If I go to a 168 tooth flexplate then will the starter work?
Old Jun 29, 2008 | 11:06 AM
rskrause's Avatar
Moderator
What kind of car? A 168 tooth is larger in diameter and may not fit. Anyway, all you need to do is specify the bolt pattern when purchasing the converter. Converter bolt patterns for Chevys are either 10.75" and 11.50". Flexplates can be drilled for either or both (dual pattern). Diameters are 12.75" (153 tooth) or 14" (168 tooth). Small blocks that came from the factory with a one-piece rear seal use the smaller flywheel and both pattern. There may be some exceptions, though I don't recall seeing any.
Rich
Old Jun 29, 2008 | 03:57 PM
silver95's Avatar
1995 camaro z28 with an LT1. If either will work then why have a 168 tooth flexplate?
Old Jun 29, 2008 | 09:30 PM
rskrause's Avatar
Moderator
I didn't say either will work. The larger flexplate will be too big for that car. You asked about the converter matching up to the flexplate, right?
Rich
Old Jun 29, 2008 | 09:47 PM
silver95's Avatar
correct.
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
Collector Car
Dec 17, 2014 01:12 PM
Dec 4, 2014 11:56 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
pnbarbee
Jul 9, 2002 06:35 AM
