Will a 153 tooth flexplate bolt to a high performance torque converter?
What kind of car? A 168 tooth is larger in diameter and may not fit. Anyway, all you need to do is specify the bolt pattern when purchasing the converter. Converter bolt patterns for Chevys are either 10.75" and 11.50". Flexplates can be drilled for either or both (dual pattern). Diameters are 12.75" (153 tooth) or 14" (168 tooth). Small blocks that came from the factory with a one-piece rear seal use the smaller flywheel and both pattern. There may be some exceptions, though I don't recall seeing any.
Rich
Rich
Dec 4, 2014 11:56 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
pnbarbee
Jul 9, 2002 06:35 AM
