Wierd Sound! :(! Sounds bad
So I am driving, and I turn off the music let off the gas and hear a knocking sound coming from the rear left. It is in synch with the turning of the wheels. The faster you drive lets say you are going 70 it makes a thump-thump-thump-thump sound.
If you are driving 35 its thump-----thump-----thump-----thump.
Any ideas what it could be? And prices? It sounds bad thats for sure.
- Z28WannaB
- Z28WannaB
Re: Wierd Sound! :(! Sounds bad
Rock in tire tread????? Bearing???? Warped rim????? Warped brake rotor???? Tire rubbing ?????? Caliper loose???? Worn shock???? Swaybar link bushing loose/worn????
Remove tire and take a look....
Can you feel anything with the sound? If you feel anything, it opens up a lot of options. If not, it narrows it down quite a bit. Best bet is to get under it and look
Tom
.Tom
To help diagnose the rear end noise, put the rear end up on jack stands and turn the rear wheels by hand. Can you replicate the noise/sound you are hearing and pinpoint the location? There are many possibilities.
Kenny
Kenny
Thanks Kenny, I wasn't really sure how to diagnose the problem. I looked around the wheel well and nothing looked out of place. Im going to try what you said and post the results.
- Z28WannaB
- Z28WannaB
Kenny
Kenny
Rock in tire tread????? No way
Bearing???? Possibly
Warped rim????? Nope
Warped brake rotor???? Brand New
Tire rubbing ?????? Nope
Caliper loose???? Nope
Worn shock???? - Possibly
Swaybar link bushing loose/worn???? Possibly
- Z28wannab
- Z28wannab
- Z28wannab
- Z28wannab
If you can see fluid on the shock, then its worn... I have that problem right now....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Mar 19, 2015 12:20 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
