Whining while turning 180º
Old Jul 23, 2009 | 11:00 PM
LT1 POWR's Avatar
I have a sort of moaning/whining coming from the 12 bolt on slow 180º turns. As far as I know, its got a posi. It didn't look like a spool when I had the rear cover off. I'd hope that strange got the backlash correct when they put the gears in. I didn't add any gm posi fluid, just royal purple gear oil. And it has probably 5,000 miles max on the rear.
Old Jul 24, 2009 | 12:12 AM
Hal Fisher's Avatar
No need to change the oil, just add one bottle of the GM limited slip stuff.
Hal
Old Jul 26, 2009 | 04:37 PM
LT1 POWR's Avatar
That's what I thought it was. I'll still have to drain a little to compensate for the extra fluid.
Old Jul 26, 2009 | 06:31 PM
If you had a spool, you couldn't do a 180-deg turn without one tire slipping and jerking all the way around the turn.
HarleyZ28
Oct 5, 2015 06:23 AM
markzzzz
May 8, 2015 09:21 AM
formula79
26
Aug 5, 2002 12:21 PM
CeeBee94Z
Jul 31, 2002 02:20 PM
Reg Kmet
Nov 15, 2001 12:33 AM
