Where to find oversized pinion bearing for setup?
I have heard that someone makes an oversized pinion bearing that can be used to set up the gears so you can find the correct shims. That way you don't have to keep pressing the bearing on and off. You use it for mock up purposes and then once you have the right shims, you can press on the real bearing. Does anyone know who makes this or where I can get one?
Sarahrope64
Nov 27, 2014 11:17 AM
Jul 4, 2005 05:00 PM
