4L60E a4 HELP need specialists PLEASE!!!
Old Jun 21, 2004 | 08:26 PM
LT1CST's Avatar
HEllo. I just put my motor back in my car. 94 Camaro. I found the leak that I was having trans related. The fluid is coming from the upper Brass Fitting line that comes from the radaitor. THeres two of them there. The upper line is leaking. I belive the two lines have BRASS Fittings on them. I TOOK it to AAMCo and they TECH Guy said he tried turning the the fitting to tighten it UP and the Fiting KEPT TUrning and Turning. He said possiblity that the Threading in the TRans CASE itself is was stripped. I think and HOPING that the brass Fiitting can be replaced. CAN SOMEONE shed some LIGHT on this. HAs anyone had any simlular problems with this cenario. IF my Brass Fitting is leaking is there anything that can be PUT on it to keep it from leaking any more. MY Car is READY to RUN. Thanks
Chris
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
