What would it take to make ABS work on a 3 Channel 9 Inch?
Old 02-19-2009, 07:11 AM
97pontta's Avatar
I've had my Moser 9 inch for a few years. Been battling horrible gear whine and have had 2 different gear shops setup the gears with no gain. So now I am going to try to do the setup myself.
Anyway while I had the rear out I was thinking about finding a way to make my 3 channel ABS work again. Correct me if I'm wrong but all it would involve is finding a way to mount a reluctor gear on the ring gear and finding a way to mount the ABS sensor in the Moser housing? From what I understand there are no 9inch rears out there that will keep the 3 channel ABS for an fbody right?
I can make a custom reluctor gear to fit the rear end but I don't know enough about the ABS system, does it require a cretin gear pitch? Thanks for any help or info.
97pontta is offline
Old 03-12-2009, 12:46 AM
gearhead3's Avatar
This should help
https://www.camaroz28.com/forums/sho...=relucter+gear
gearhead3 is offline
squarehead
01-15-2015 07:02 PM
ddr698
01-09-2015 10:05 AM
siguy
11-27-2014 10:07 AM
Eric H
08-10-2002 06:39 AM
Highlander
08-09-2002 02:30 AM
Quick Reply: What would it take to make ABS work on a 3 Channel 9 Inch?
