What would it take to make ABS work on a 3 Channel 9 Inch?
I've had my Moser 9 inch for a few years. Been battling horrible gear whine and have had 2 different gear shops setup the gears with no gain. So now I am going to try to do the setup myself.
Anyway while I had the rear out I was thinking about finding a way to make my 3 channel ABS work again. Correct me if I'm wrong but all it would involve is finding a way to mount a reluctor gear on the ring gear and finding a way to mount the ABS sensor in the Moser housing? From what I understand there are no 9inch rears out there that will keep the 3 channel ABS for an fbody right?
I can make a custom reluctor gear to fit the rear end but I don't know enough about the ABS system, does it require a cretin gear pitch? Thanks for any help or info.
squarehead
01-15-2015 07:02 PM
