What shifters will a Lou's short stick work with?
will it work with a stock 96 lt1 shifter? and what aftermarket shifters will it work with
also do you know if a hurst shift **** will fit on it?
i know these are probably all retarted questions, just needed to know
thanks for the help
thanks for the help
Re: What shifters will a Lou's short stick work with?
well Lou makes several different sticks.
the standard one fits factory 6spd shifters and the upgraded Hurst shifter found in some SSs and WS6s. and a factory Hurst **** will fit. it should fit your LT1 fine
i believe it will also fit the 5sp shifter in the V6s.
most other aftermarket shifters have different bolt patterns.
slothgrant
Aug 22, 2002 03:01 PM
jim88iroc305
Aug 13, 2002 09:24 PM
