What needs to be done to a used Mcleod ST before installed?
Old Jul 29, 2004 | 11:30 AM
fstenuf's Avatar
just like the title says. my tranny will be pulled and i didn't know what all needs to be done to the clutch(if anything) before reinstalling it. thanks!
Old Jul 29, 2004 | 11:49 AM
GREGG 97Z's Avatar
Re: What needs to be done to a used Mcleod ST before installed?
If you are just pulling the trans to have work done to it you don't need to mess with the clutch at all. The trans bolts on to the clutch bellhousing, you dont have to touch the clutch to remove the trans. Just dont push down on the clutch pedal while the trans is out or you will have to re-align the disc.
Old Jul 29, 2004 | 01:10 PM
fstenuf's Avatar
i'm having the clutch looked at because it won't let me get into reverse at all unless my car is not running and it has a hard time getting into first and down shifting. so i had it looked at and they said that it could be the pressure plate or something is hitting the input shaft on the tranny. any info would be great thanks!
Old Jul 29, 2004 | 01:40 PM
GREGG 97Z's Avatar
Kind of a misleading title and question if thats the problem your having. I'm not sure how the PP could be hitting the input shaft but I've never worked with or seen a ST. Maybe your PP isnt releasing enough, it could be a problem with the clutch master cylinder, I think I've heard the ST comes with an adjustable master cylinder.
Old Jul 29, 2004 | 01:59 PM
fstenuf's Avatar
sorry about the title, i was reading somewhere and thought i read about how something needs to be rebalanced or surfaced before installing. if someone new more about the ST and could give me some pointers that would be awesome! thanks!
Old Jul 29, 2004 | 05:26 PM
atljar's Avatar
You can buy a internally balanced flywheel and also an externally balanced. Which one depends on how you had your 396 balanced.
Old Jul 29, 2004 | 11:20 PM
fstenuf's Avatar
Do i need to have my flywheel balanced?
Old Jul 31, 2004 | 08:28 AM
iniviate's Avatar
yes, unless your 396 is using a stock balance flyhweel.... and even then i think i'd still recommend having it done
if your motor is internally balanced, you will want the street twin balanced to "0" .... supposedly if you take the weight off the back of the flywheel this will make it 0, but even with the weight removed mine still had to be balanced.
if your motor is balanced through the flywheel, you'll need to take both flywheels down there and have them make the ST match your old one.
Old Aug 1, 2004 | 07:23 AM
fstenuf's Avatar
Do you also recomend having it surfaced to removre the burn marks?
Old Aug 1, 2004 | 08:16 AM
camel's Avatar
sounds to me like a problem with your reverse lockout solenoid.
Old Aug 1, 2004 | 08:25 AM
fstenuf's Avatar
What about not being able to downshift and getting it into first at a dead stop? cuz its also not letting me do those two things either.
Old Aug 1, 2004 | 08:34 AM
camel's Avatar
guess i should have read that whole post and not just skimmed over it. i am not too sure about why it would act like that. but if you find out let me know, my st is coming in a week or 2.
Old Aug 1, 2004 | 08:36 AM
fstenuf's Avatar
yeah i've been doing a lot of reading and they say they're a bitch to get right...but once they are HOLD ON! i loved to give it hell in my car no slipping at all!
Nov 18, 2023 07:21 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Ringmaster72
Mar 19, 2015 03:32 PM
BPS
9
Mar 5, 2015 10:51 PM
Don 97 SS
Jul 11, 2005 08:50 AM
