what in the heck-o would cause this crack?
Old Mar 9, 2006 | 11:18 PM
  #16
amean94ta's Avatar
Re: what in the heck-o would cause this crack?
i have done that before years ago from launching my 77 camaro cracked into the case also and dumped fluid everywhere
Old Mar 10, 2006 | 08:38 PM
  #17
baddboy1705's Avatar
againt everyone telling me not too..... i TIG welded it today. took me 4 hours to do but i think it loks great and i measured everything up and its A-ok... posting pics of it soon! thanks fellas
Old Mar 10, 2006 | 09:31 PM
  #18
12SCNDZ's Avatar
A few things can cause the case to crack like that. Were all your torque converter bolts tight? Was your transmission mount in good condition?
Frank
Old Mar 11, 2006 | 10:48 AM
  #19
mounts were good as new...and the torque converter bolts were a *itch to get loose... check out these TIG'ing skills
Old Mar 11, 2006 | 02:50 PM
  #20
Question Re: what in the heck-o would cause this crack?
anyone think i should get a new torque converter while i have my trans out now? what kind? im looking to spend around 300 but will spend more to get a nicer working one
Old Mar 11, 2006 | 09:36 PM
  #21
triumph's Avatar
I have seen them break like that from hooking up hard when not using subframe connectors.Is this a T top car? The bodys on f-bods will twist and t top cars get really out of shape. Yes you will need a new convertor as yours you can bet is damaged. Steven
Old Mar 12, 2006 | 01:39 PM
  #22
you think ill be alright with a torque flush? i know a guy that will flush it for $20... yes its a T-top car...but I really dont think Ive caused it from hooking up. I dont beat on the car ALL the time, and my t-tops fit perfect
Old Mar 12, 2006 | 02:34 PM
  #23
Loadre's Avatar
You can't truly flush a converter, only pour fluid in and let it drain back ou.
Old Mar 12, 2006 | 02:55 PM
  #24
Dave89IROC's Avatar
you can with a convertor flush machine
Old Mar 12, 2006 | 02:58 PM
  #25
Loadre's Avatar
Elaborate?
Old Mar 12, 2006 | 03:07 PM
  #26
yeah he has a machine
Old Mar 12, 2006 | 04:44 PM
  #27
triumph's Avatar
When the bellhousing broke you put alot of stress on your stator input on the convertor yours is most likely a doorstop now.........GET A NEW ONE OR have yours rebuilt. Steven
Old Mar 12, 2006 | 06:38 PM
  #28
you can have your torque converter rebuilt?!?!? this is news to me...
Old Mar 12, 2006 | 06:46 PM
  #29
Dave89IROC's Avatar
yes, you can, they put it in a special lathe that cuts the weld seam, then they can replace anything inside(as needed), this is when you can get it restalled as well, then they weld the seam back up
Old Mar 13, 2006 | 04:59 PM
  #30
somehow i think its going to be cheaper just to buy a new one but i learned something new! haha thanks
