What gears do I have?
Old Dec 10, 2004 | 11:08 PM
DavesLT1's Avatar
Question What gears do I have?
I've looked around and it looks like GM put different gears in the rear ends for different cars? I'm not too sure about this as I am new to F-bodies, but if it is true how do I find out what gears I do have? Also, what is the sive of the rear end of 97 Camaros and number of teeth so I can order better gears if wanted?
Old Dec 11, 2004 | 01:58 AM
5.0THIS's Avatar
Re: What gears do I have?
If your car is a 6 speed it has 3.42s from the factory. IF it is an automatic is has either 3.23s or 2.73s. There is a code in the glovebox amongst all the others.
GU2= 2.73s
GU5=3.23s
GU6=3.42s
Old Dec 11, 2004 | 02:09 AM
Bersaglieri's Avatar
Another way to tell if your glovebox is hard to open without a screwdriver like mine is. If you have an Auto, if you have a 1st gear selectable you have 3.23's, if you have only as low as 2nd gear selectable you have 2.73's.
Good Luck.
-Dustin-
Old Dec 11, 2004 | 10:51 PM
DavesLT1's Avatar
Thanks for the info, with my 6 speed I have 3.42's then. Would it be worth it for me to increase to a 3.73? Or, should I go to 4.10? Also, what is the differential size and teeth number?
Old Dec 11, 2004 | 11:57 PM
Capn Pete's Avatar
With an M6? DEFINITELY go 4.10's. I've even got them in my A4!
When buying a new set, order them for a GM 7-1/2" / 7-5/8" 10-bolt (they're standard from '82+ F-bodies I believe, and also used in other GM vehicles).
Right now the 3.42's are 41 teeth (ring gear) and 12 teeth (pinion). 4.10's are 41 / 10 (do the math).
Old Dec 12, 2004 | 03:03 AM
5.0THIS's Avatar
what gears you'll want will depend on your future plans. If you're planning on going with a power adder in the future you might want to stay stock or go to a 3.73. IF you'll be just a bolt on car or all NA, you might go 4.10s
Old Dec 12, 2004 | 11:52 AM
DavesLT1's Avatar
Well, I don't plan to SC or turbo the engine, but I have thought about using a shot of juice. Probably about a 100 shot, and then only at the strip. So would the 4.10's be too much, or what I should get?
Old Dec 12, 2004 | 04:28 PM
5.0THIS's Avatar
Personally I'd go with 3.73s, to retain better top end speed and more streetability, but the 4.10s will work.
Old Dec 12, 2004 | 10:10 PM
DavesLT1's Avatar
How bad would 4.10's hurt the top end speed? I talked to a friend of mine who just put 3.89's in his 63 Galaxie with the Ford 9" rear end and a 390 CID engine, and he says he has trouble going over 70 MPH. Is it just because the 390 is a TQ monster or is this the case with all steep gears?
Old Dec 12, 2004 | 10:31 PM
Red5.7's Avatar
Probably just the ratio in the trans making it unbearable over 70 MPH for your friend.
I have 4.10s and I can cruise the freeway at 70 MPH in 6th gear turning a hair under 2000 RPM or thereabouts. The freeway isn't a problem because of the nice overdrive gears
BTW, in the quarter with 4.10s and stock sized tire you will run out of gear at about ~112 MPH in 4th. How high of a top end were you thinking?
Old Dec 12, 2004 | 10:58 PM
DavesLT1's Avatar
Probably no more than 125 MPH. No real need to go much faster. So 4.10's would be best then?
Old Dec 13, 2004 | 01:27 AM
5.0THIS's Avatar
There are goods and bads to every gear. You'll pull harder down low with 410s, but on the highway they wont pull as hard as a similarly powered car wit 342s or 373s IMO.....
Old Dec 14, 2004 | 03:51 PM
DavesLT1's Avatar
Well, within a year or so I plan to have a stroker kit for it, and maybe NOS. With these on there, would the 4.10's be too steep for streetability?
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
