what gears for blown 383
hey guys, i will be running the mods in my sig. i just bought a strange 12 bolt with eberything but gears. it had a set of 4:11's but i know there no good for FI cars. befroe the 12 bolt i had stock rear end with 3:42's. should i stick with 3:42's or go to 3:73 or 3:90? its a street car but i dont car much about highway use to much seeing as its a 6 speed. thanks
What are you using the car for? What kind of tires?
For the track, rear axle ratio is determined by trap speed, engine redline, tire diameter and peak HP RPM. For the street its more an issue of what kind of traction can you get with the particular tires you are running.
well the car is a street car. it will see the track a few times for fun of course. but really i want it for light to light. i should be getting my hands on a set of c6 rims 18x10.5 rears with 295/?/18 drag radials. hope this helps. thanks
Yes, running a Moser 12 with 3.73:1 gear with a TruTrac diff. (97ss 383 - D1 M6). Sorry, I'm not set-up for drag racing. More street-road/ cornering. 4.10:1 caused alot of wheel spin (old 7 1/2" 410 geared rear) even with a decent tire (315-35-17 bfg-kd) upgrade. Almost went 3.90:1. I had a 3.89:1 gear in my old boss 351 and liked it. With a T56, there are two overdrive gears, so, a cruz with 390 gear should be OK. B.
