What fluid in a Dana 60?
I thought there would be threads on this already, but I couldn't find any.
My rear is broken in now, about 7500 miles total. I have been running the Lucas 85w 140 non-synthetic I think it is... Strange recommended it.
Can I go synthetic now, or should I never do that? I remember Strange saying not to, but they wouldn't tell me why. Wouldn't synthetic make everything last longer?
I am running the true track cone style auburn posi, if that matters.
I just want to know what people are running and what works.
I am gonna pull the cover off and just inspect the gears and everything to make sure things are wearing well.
THANKS!!!
Cody
THANKS!!!
Cody
Yes, it came with fluid, and after 500 miles I changed it out to the lucas stuff as recommended by Strange.
Same with the rearend in this case. The thicker gear oil would take up additional slack in the rear and make it quieter, as well as provide cheap insurrance that it doesn't break. Know what I mean or am I just being dumb and I should just put the lucas back in it?
What makes you think that synth is thicker? Rear end fluid is all about what is called high pressure additives which get between the gears and cushion them from touching each other. The dino gear oil works so well that in non-posi rears that the oil change recommendation is never.
Oil recommendations for posi rears are all about the method of making it keep torque to both wheels, keeping the noise down, and making it last a long time.
Synth may be too slippery to let the cones drive both axles as designed. Don't know. Maybe Strange doesn't know. But they do know from years of experience that dino oil works just fine.
Yes. Dino oil is non-synthetic oil. It comes out of the ground as crude oil and is refined. Have you ever seen the Beverly Hillbillies? (black gold, texes tea). Some call it dino oil because they believe it was formed from decomposed dinosaurs, animals, and plants. Gasoline, diesel fuel, Jet fuel, etc. are sometimes called fossil fuels. There are many other theories as to how oil was formed.
Thanks!
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
