What is the best set up?
Old Apr 7, 2008 | 11:15 AM
gpt68's Avatar
I have a 1993 trans am thats turbo charged puttin out round 500 at the motor with 8 psi and it has the stock rear end and transmission... wat would be the best route.. beefing up the stock transmisson and rear end by performing a performance rebuild or purchasing a different set of both?? i like the gear set in the rear end right now however, i need some advice a to which way i go.. at maximum performance it throws out around 700-750 lbs of torque when there is full bost.. Thank you for your tme
Old Apr 7, 2008 | 04:07 PM
AutoRoc's Avatar
We need more info. Is it a race car only or a street driven car? Would you like a trans-brake to build boost at a dead stop? Do you have a tight budget for mods? You could rebuld it all and have it last a long time but then again it could fail. The stock rear can be fragile but some have made them last a LONG time behind good power. Same goes for the transmission.
Or you could do a 4R70W ford trans with a transbrake, a TH350 or TH400 chevy trans, a torque converter setup for your engine/turbo combination, a stronger driveshaft is a must, and you can get into a 12 bolt, 9", or S60 Dana rearend. Options aren't a problem anymore.
HectorM52
Jul 30, 2017 11:46 AM
z28leno
Mar 12, 2015 07:42 AM
FredM
Mar 6, 2015 03:04 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Jan 23, 2015 01:13 PM
