What bearing is this?
Old Sep 6, 2008 | 09:22 AM
Mtxz453's Avatar
Im putting in my new spec clutch and it seems as though a bearing has broken and the outer shell of it is still stuck and wedged into wear the shaft from the trans goes through the clutch and flywheel. What bearing is that way inside that the tip of the shaft rests in? I think spec gave me a new one anyway but i just wanna make sure thats what its used for. As of now it doesn't fit but it seems its because that outer shell that broke when i was taking the trans out is stopping it.
Old Sep 6, 2008 | 09:49 AM
RUDEDOG's Avatar
Pilot bearing.
Old Sep 6, 2008 | 10:20 AM
Mtxz453's Avatar
any tips on getting this shell out? I'm only breaking off bits of it, i can't get underneat it with a screwdriver. I've heated it up with a torch but i didn't wanna get it to hot because of the seals.
Old Sep 6, 2008 | 02:56 PM
Green96Z's Avatar
They have special pullers for them. Or you can try packing grease or wet toilet paper in there and pounding it out with a socket extension.
Old Sep 8, 2008 | 09:48 PM
TW95Z's Avatar
I had one pilot bearing that I had to carefully chip at with a hammer and small chisel before it was loose enough for the puller to get it. Soak it in penetrating oil overnight.
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
