What 4l60e trans will be a direct replacement for me?
Old Jul 23, 2007 | 08:04 AM
ninety4formula's Avatar
I am hoping to find a trans to replace my 94 4l60e with so that I can sell it. Right now the fluid looks dark and has metal shavings in it. I also has resistance if you try to go in reverse like the emergency brake is on but its not. I am trying to weigh my options as to just buy a used one or rebuilding the one I have, but Idk how bad the damage is. My uncle rebuilds trannys on the side and said it would be $200 plus any parts. I have also posted that I want a 4l60e over in the parts wanted forum. What years are interchangable that are direct replacements? I think I've heard some years won't work. Thanks for the info.
Brian
Old Jul 23, 2007 | 12:02 PM
12SCNDZ's Avatar
You'll have to locate a 1994 4L60E. No other years are a direct replacement. GM switched to the Pulse Width Modulated (PWM) lock-up strategy in '95, and the transmissions had an extra solenoid to conbtrol the converter apply.
Frank
CPT
jay_lt4's Avatar
94 is all by itself
Old Jul 23, 2007 | 12:12 PM
What would I have to do to get another year in there? I have someone that has a '95 that they want to sell me.
Old Jul 23, 2007 | 01:05 PM
anilator's Avatar
I have a used 4l60e out of a 1994 Z28. It has 65k miles on it and it still worked when I took it out. I got a cam and nitrous so I upgraded. You can have it for $250.00. It is at my shop in Phila, Pa. It is stock w/the stock torque converter still attached.
Old Jul 23, 2007 | 04:43 PM
Are there any leaks or any problems at all with it? Did you use it when you had the cam or the nitrous?
Old Jul 23, 2007 | 06:08 PM
anilator's Avatar
Absolutley not. The car was a full bolt on car before the cam and nitrous. I changed the cam, trans and added the nitrous together.
I did race the car at the track with the bolt on stuff a few times throughout the years, but it was mainly a Sunday driver. I changed the oil in the trans every other year since I did not drive the car much. The fluid was always bright red.
The car has less than 70k miles on it over 13 years and I am the original owner.
Old Jul 23, 2007 | 06:31 PM
Well it is the best deal that I have had come my way so far. Tonight I am talking to my step dad who would be the one helping me. I will let you know as soon as I can.
Brian
Old Jul 23, 2007 | 08:00 PM
anilator's Avatar
No problem. If you need it, just let me know.
Brake_L8
Jan 20, 2015 09:44 AM
Jan 5, 2015 07:14 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Sarahrope64
Nov 27, 2014 11:17 AM
jim88iroc305
Aug 13, 2002 09:24 PM
