Weird T56 issue
Old Mar 30, 2008 | 05:12 PM
SS Joe's Avatar
Weird T56 issue
The Camaro SS in my sig had what I thought was a clutch issue recently; I was about to exit the highway, and it wouldn't downshift into any gear but 2nd (I had been in 6th). I limped it home (barely), took it apart, and checked everything out-the hydraulics hadn't ruptured, the pedal still felt ok, and when I pulled the trans, even the clutch/pp/tb showed no obvious problems. I replaced the clutch assembly, and its doing the exact same thing- when running in neutral, you can't shift into any gear without pretty severe grinding. It will shift into each gear fine with the engine not running. Any idea whats wrong? I'm pretty sure it must be something internal with the transmission. Thanks.
Old Mar 30, 2008 | 05:17 PM
Pyrodawg's Avatar
my guess is the shift forks and the keys/struts inside it
Old Mar 30, 2008 | 06:08 PM
SS Joe's Avatar
How big a deal is that to fix? any idea of the cost (ballpark)? I have rebuilt 4 speeds before and will probably try to do this myself.
Old Mar 30, 2008 | 06:14 PM
Pyrodawg's Avatar
im not sure if this site has sponsors that have parts but here
http://www.ddperformance.com/T-56%20Parts.htm
Old Mar 30, 2008 | 06:16 PM
SS Joe's Avatar
Thanks, I'll give them a call tomorrow.
Old Mar 31, 2008 | 08:26 AM
rngilliland's Avatar
When you can shift normally with the engine off but it grinds with the engine running it is usually because the clutch isn't releasing completly not because of a transmission problem.
Old Mar 31, 2008 | 09:45 AM
Pyrodawg's Avatar
i could shift into second with the car off just fine when i broke the 1-2 slider and one of the keys on second gear... but when the car was on it would grind and kick me out of second
Old Apr 3, 2008 | 04:40 AM
SS Joe's Avatar
I have experienced that before too, but I would find it highly unlikely since I changed the clutch/pp/tb and still have the exact same issue. The pedal feels fine, and the hydraulics aren't leaking or showing any issues.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
timmy39120
May 8, 2015 11:41 AM
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
cmdeshon
Jan 4, 2015 11:15 AM
