Weird noise when making a turn
Old May 6, 2009 | 12:47 PM
lovemyblackz28's Avatar
Question Weird noise when making a turn
Not sure if this belong in this section. Lately whenever I make a turn, left or right, I hear this moaning sound when Im turning the steering wheel. It only happens when Im making a turn at like 5mph. It sounds like its coming from the back though I could be wrong. Any ideas?
Old May 6, 2009 | 12:52 PM
km9v's Avatar
Sounds like the power steering pump.
Old May 6, 2009 | 01:10 PM
The noise only happens when the car is moving. If I was at idle and turning the wheel, You dont hear the noise. Could that still be the power steering pump?
Old May 6, 2009 | 01:27 PM
km9v's Avatar
Yes, typically a PS noise will happen when the engine is under load @ low speed. First thing, have you checked PS fluid level?
Old May 6, 2009 | 09:21 PM
93v8clone's Avatar
ummmmm, if it was p/s ya would hear it more so at idle as less pressure and pump action .........could be the rear diff groanin or the e,brakes hangin a little or the breaks themself,s moanin .i have the same problem in mine and im just to lazy to really track it down all the way
Old May 9, 2009 | 07:14 AM
AL SS590 M6's Avatar
Moderator
Front wheel bearings.
Old May 9, 2009 | 09:48 AM
Coming from the back? You need some GM limited slip additive. The plates will groan, pop, squeak and clunk-more noticeable on slow sharp turns.
97z28k&N
Jan 9, 2015 04:58 AM
jj71787
Dec 30, 2014 02:15 PM
ro2207
Dec 4, 2014 06:18 PM
NewsBot
Dec 3, 2014 12:30 PM
squarehead
Nov 21, 2014 08:02 PM
