Vibration Solved!
Old Sep 25, 2007 | 08:39 PM
Andy30thZ's Avatar
Vibration Solved!
After three years of friggin around I fixed my vibration problem!!
I bought a LS1 driveshaft thinking that would fix my vibration. When it didn't, I assumed that the driveshaft couldn't be the problem and started looking everywhere else.
http://web.camaross.com/forums/showthread.php?t=536982
After an extensive search this summer I concluded both the LT1 and LS1 shafts must be bad. I sent my LS1 shaft to Dennys Driveshaft http://www.dennysdriveshaft.com/
He told me it was no good and built me a custom steel shaft for $350. ($400 with tax and shipping)
Problem solved. I've had it up to 120 with 4.10's, no vibrations.
$350 sounds expensive, but I bought the LS1 shaft used $160 shipped, 60 bucks for joints, $20 for a local truck shop to check it for straightness and balance (it tested good for them.....they didn't spin it fast enough) So i had $240 in a shaft that I had to throw away. Looking at it that way, $350 dosen't seems so bad for a custom made shaft spun to 6500rpm.....
Old Sep 25, 2007 | 08:50 PM
wrd1972's Avatar
Now that I am close to 400 RWHP I have been thinking about selling my 1LE aluminum shaft and getting a good steel one like this one.
Is the rear end noise any quieter with this shaft, many think that the aluminum DS amplifies noise?
Old Sep 26, 2007 | 06:40 AM
Andy30thZ's Avatar
Believe it or not, I used junkyard 4.10s from an S10 and they are dead quiet. So I don't know if the aluminum shaft adds noise.
Old Sep 26, 2007 | 03:55 PM
Kevin97ss's Avatar
Knew that had to be it Too bad that LS1 shaft was money wasted but at least now its fixed.
Old Sep 30, 2007 | 09:17 PM
maybe2fast's Avatar
what was the initial vibration noise?
Old Sep 30, 2007 | 10:08 PM
Daniel6718's Avatar
motor rpm has nothing to do with driveshaft rpm...its mph vs gearing just so you know...
glad yuo got it fixed it can be annoying my steel had a slight vib...swapped for a ls1 shaft and its good now
Old Oct 1, 2007 | 01:44 PM
chevelles101's Avatar
Actually motor rpm does have something to do with driveshaft rpm. For example if you are in fourth gear in a T-56 at 3000 rpm your driveshaft will also be at 3000 rpm and if your at 4500 rpm your driveshaft will be at 4500 rpm.
Old Oct 2, 2007 | 07:23 AM
Andy30thZ's Avatar
Just as an update.... I reinstalled my ES poly trans-mount with the preload plate, with no vibrations.
Also, I finally ran the car (only two passes before rained out)
14.02 @ 101.95. I need to learn how to drive. My 60's suck... 2.18.
I picked up almost 2 mph with the gears. Stock 97 LT1 6sp, catback, CAI, hurst shifter, 4.10's
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
ZXXVIII
Sep 1, 2015 10:13 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
