valvebody and th400 rebuild question
Old Jan 13, 2007 | 02:06 AM
romoranger's Avatar
i bought a th400 from one of my friend's friend's (yeah i know) that was disassembled. i don't really know much about it except for the fact that it was behind a drag chevelle for a while. it seems like it had a nice race build on it (a bunch of the red clutches and such) and the one servo/gear thing the oil holes were drilled out to 3/16". i am trying to figure out what kind of valvebody it has (whether it is a full manual or automatic), if you guys could help me. i have provided a picture underneath
http://i5.photobucket.com/albums/y18...r/P1010115.jpg
http://i5.photobucket.com/albums/y18...r/P1010116.jpg
i was also wondering if anyone knew of any good online resources for rebuilding th400's, as i am going to attempt to do it myself. i have a really good book but all the pictures are in black and white. color pictures, or even just a view of what it looks like put together would help me out a lot.
Old Jan 15, 2007 | 02:28 AM
romoranger's Avatar
can anyone tell by looking at it if it is a full manual or automatic valvebody? i can take more pictures if need be
Old Jan 15, 2007 | 11:50 AM
12SCNDZ's Avatar
Looks like a stock valve body to me. Shoot me a picture of the worm track side. Most manual valve bodies do away with the governor feed tubes. Did the transmission have a governor in it?
Frank
CPT
Old Jan 15, 2007 | 03:35 PM
romoranger's Avatar
here is the worm side
http://i5.photobucket.com/albums/y18...r/P1010119.jpg
and i beleive this is the governor
http://i5.photobucket.com/albums/y18...r/P1010120.jpg
http://i5.photobucket.com/albums/y18...r/P1010121.jpg
Old Jan 15, 2007 | 03:42 PM
romoranger's Avatar
the other thing is i think there is a chance this case is cracked although i am not sure. i have never seen another th400 case. maybe if you could let me know what you think
http://i5.photobucket.com/albums/y18...r/P1010122.jpg
here is a picture of that same spot, but from the inside
http://i5.photobucket.com/albums/y18...r/P1010123.jpg
here is that same picture from farther back
http://i5.photobucket.com/albums/y18...r/P1010124.jpg
and here is something towards the front of the case
http://i5.photobucket.com/albums/y18...r/P1010125.jpg
if it makes a difference i do have a block off plate for one of the rear holes on the side, i think for where the modulator would go
Old Jan 15, 2007 | 07:58 PM
12SCNDZ's Avatar
That's not a manual valve body. I can't really see anywhere where the case is cracked. are you referring to the rough casting?
Frank
CPT
Old Jan 16, 2007 | 12:42 AM
romoranger's Avatar
yes i am referring to the casing. if its just a rough casting then i am happy . would it be better to convert it to manual or just buy a manual valve body?
RUENUF
Mar 13, 2016 03:39 PM
Sergio
Jan 27, 2016 04:27 PM
Nostang 96z
Sep 15, 2002 10:15 PM
Nostang 96z
Sep 14, 2002 08:22 PM
