Two or three series question... (A4)
Old Dec 21, 2003 | 09:49 AM
Myxtreme1's Avatar
Ok, I know there is a way to look at the shifter indicators to see which one I have. I beleive I can shift odwn to 1st gear in mine. Which one do I have. I will be buying 3:73's soon and they say I need to know which series carrier I have. Thanks!
Old Dec 21, 2003 | 12:15 PM
2001NBMZ28's Avatar
Look on your driver's side door at the RPO codes
GU2 - 2.73 (2 series)
GU5 - 3.23 (3 series) or by rpm/mph at
www.f-body.org/gears
Old Dec 21, 2003 | 12:24 PM
revtime's Avatar
If it says 1 on your shifter and you can pull the shifter back into first then you have 3.23s.
RPO code will verify this.
Old Dec 21, 2003 | 12:58 PM
Myxtreme1's Avatar
Thanks guys! I will double check this.
Old Dec 21, 2003 | 03:59 PM
Capn Pete's Avatar
***NOTE***
Just an FYI for anyone reading this..............using the method above (whether 1st gear can be selected or not) to determine 2.73's or 3.23's is ONLY applicable with LT1 F-bodies. GM changed that with LS1 cars. Even with 2.73's, you can now select 1st gear, whereas you could not with an LT1 car. This means you must go by the code listed above (GU2/GU5) or MPH @ a given RPM.
Old Dec 22, 2003 | 08:05 AM
2001NBMZ28's Avatar
Another note on 1st gear selection - someone could have done the 2.73 gear selector mod
www.fbody.com/tech/details.cgi?id=7
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
KamikaZ28
May 28, 2015 12:45 AM
May 1, 2015 01:14 PM
