Two different ranges per gear???
Old Nov 18, 2003 | 06:46 PM
2Fast94TA's Avatar
im new to chevy auto transmissions, and it seems like in 3 and OD there is like a hi and low gear because the rpm's keep changing in these gears. is it just me??
Old Nov 18, 2003 | 07:57 PM
rskrause's Avatar
Moderator
Re: Two different ranges per gear???
You have a lockup torque converter. You are probably feeling the converter lock and unlock. In highway cruising, you will see a 200-300rpm increase when the converter unlocks.
Rich Krause
Old Nov 18, 2003 | 08:10 PM
OldSStroker's Avatar
Re: Re: Two different ranges per gear???
Rich Krause
Yep, and lockup occurs in both 3rd (if in D) and 4th (in OD) above about 40 mph.
Old Nov 18, 2003 | 09:15 PM
2Fast94TA's Avatar
ohh... thanks I sort of thought about that.
carl.froehlich
Mar 13, 2015 12:38 AM
edman
Jan 22, 2015 02:45 PM
NJ SPEEDER
Aug 19, 2002 12:23 PM
