transmissions the same?
Old Feb 3, 2006 | 09:12 PM
97formula808's Avatar
are the tranny's for the ls1 and lt1 the same? thanks in advance.
Old Feb 3, 2006 | 10:49 PM
Pro Built Automatics's Avatar
Re: transmissions the same?
No, & they use different torque converters.
Old Feb 4, 2006 | 07:24 AM
12SCNDZ's Avatar
Dana,
I've never tried this, but I think it may be possible. What about a bellhousing from a truck (Let's say '98 truck). on a 2 piece case. The bolt pattern on the bell is a traditional SBC pattern on those, and so is an LT1. If you use an LS1 style converter for the larger input splines, wouldn't this work? Are the crossmembers different on an LT1 and LS1?
Obviously this would only work on '95-up 4L60E's.
Frank
CPT
Old Feb 4, 2006 | 11:39 AM
MyShibbyZ28's Avatar
I believe the shafts are longer on LS1 trannies.
Old Feb 4, 2006 | 11:57 PM
I think the non LS1 bellhousing is about 6.75", and the LS1 is about 7.25", about .5" in difference length. I don't think this will work.
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
