transmission shift problem
Old Feb 18, 2014 | 10:17 PM
Joshua95z28's Avatar
I have a 95 z28 with an automatic transmission. When accelerate through first gear I have to let off the gas before it will shift to second. I have heard it needs a sensor changed. Can anyone confirm this or tell me what I need to do. I am no transmission guy so any help would be appreciated.
Old Feb 20, 2014 | 08:53 AM
12SCNDZ's Avatar
Re: transmission shift problem
Is the transmission capable of shifting through all the gears? Many times when this complaint pops up it's because the transmission is actually making a 1-3 shift. If it is making all the shifts, you might want to check your Throttle Position Sensor (TPS) voltage. You should have .5 Volts at idle and roughly 4.5 Volts at WOT. What condition is the fluid in? Is it dark or does it smell burnt?
Frank
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
jackpawt883
Feb 26, 2015 09:04 PM
Cam's maro
Dec 28, 2014 09:30 AM
Sarahrope64
Nov 27, 2014 11:17 AM
