Transmission Pump
Old May 8, 2007 | 12:28 PM
sweetblue's Avatar
Transmission Pump
So the other day the transmission decided to stop working. Basically not engaging at all. Got it home pulled the line that goes into the radiator to see if the pump was working, and what do ya no it wasn't pushing any fluid at all. Now my question is do I, should I do complete rebuild of the tranny? Thr fluid smells fine, now metal in it as far as I can see. The tranny was rebuilt before with a hardened sunshell gear high energy bands, different clutch packs, bigger valves, shift kit and syntetic fluids. It was slipping before the pump died. Was just wondering if I should replace the pump, whats a good pump and how hard is it to replace the pump and is there any guides to do it on the web tha you all may know of? Thanks Desmond!
Old May 8, 2007 | 05:17 PM
Pro Built Automatics's Avatar
You will need to get it apart to see what has happened before you know what to do exactly.
Magenta_Hearts
Mar 29, 2017 08:54 PM
thenewkid
Apr 12, 2015 07:42 PM
jackpawt883
Feb 26, 2015 09:04 PM
thenewkid
Nov 27, 2014 09:41 AM
dmaastr
9
Jul 1, 2002 02:22 PM
