Transmission Pan bolts??
Old Apr 22, 2005 | 09:54 AM
Myxtreme1's Avatar
Does anyone know the size? I'm not at home right now and wanted to pick some up while I am close to the store. Thanks!
Old Apr 27, 2005 | 08:07 AM
Myxtreme1's Avatar
Re: Transmission Pan bolts??
Does anyone know the size??
Old Oct 26, 2005 | 06:02 AM
Frank89IROC's Avatar
M8 x 1.25 x 20
Old Oct 26, 2005 | 07:27 AM
They have a special washer on them that should be used.
Old Oct 28, 2005 | 09:40 AM
Myxtreme1's Avatar
UH OH...so is there anywhere I could pick up these special washer? Mine has been back together for a couple months just straight bolts but it hasn't been driven much. Might be leaking, I'm not really sure. Thanks!
Old Oct 28, 2005 | 04:05 PM
The washers keep you from bending the pan up. The washers are concave, facing the thread end. If you screw them down too much, the washer flips the other way. In that case, you are supposed to replace them. I believe the washer is part of the stock bolt. If you are surviving without leaks, I wouldn't worry too much about it.
Old Nov 2, 2005 | 12:29 PM
Myxtreme1's Avatar
Cool, I will keep a close eye on it. The problem is that I actually spilt a bit of trans fluid and I need to clean it all up off the bottom side so I can distinguish a leak from a drop.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
jackpawt883
Feb 26, 2015 09:04 PM
