transmission mount
Old May 28, 2007 | 04:18 PM
bombebomb's Avatar
transmission mount
I broke mine yesterday so ordering a new one today, when I go through summit it does not have 93-97 as an option just 98-02, I know 98-02 has same transmission, but will the mounts stil work on my 94?
http://store.summitracing.com/egnsea...=KeywordSearch These are the ones listed for a 98
Old May 28, 2007 | 06:53 PM
ChicagoTransAm's Avatar
Looks to be the "right" one.... Just don't install it with the preload plate (you'll see what I mean when you get it)
Old May 28, 2007 | 06:54 PM
CamaroSS30thAnn's Avatar
yep dont use the pre-load plate. Otherwise youll get a lot of vibrations.
Old May 29, 2007 | 03:34 AM
bombebomb's Avatar
Ok guys thanks, be ordering today!
Old May 29, 2007 | 02:58 PM
bombebomb's Avatar
ok im ordering now, any objections on it being the wrong part? Ok iv orderd.
Old May 31, 2007 | 09:22 AM
bombebomb's Avatar
ok I got it today, I dont see anything that screams preload plate though. All I got is this
mount
2 7/16"-14X1 1/2" Stud
2 7/16"-14 NUT
2 7/16" Lock Washer
2 7/16" Flat Washer
So is the preload plate even here?
Old May 31, 2007 | 06:44 PM
bombebomb's Avatar
Ok its installed but now the car shakes at around 2500 rpms, even when its in park.
Old Jun 4, 2007 | 08:17 AM
Capn Pete's Avatar
Yup, shoulda bought a factory LS1 mount . I couldn't take the vibes that the ES poly mount transmitted through the car, so I'm still on my stock mount, with ~60k on it, drag raced lots and road raced quite a few times as well . It's significantly better than the factory LT1 mount, but it's softer than the poly mount, so it doesn't rattle your fillings out .
Old Jun 4, 2007 | 03:38 PM
it must just be certain people but i dont get many if any vibrations from my poly mount. ...... it does jerk a little harder now through the shifts but other than that it doesnt bother me. Plus the ES poly mount is the one that u shouldnt use the pre-load plate on, with that plate on it vibrated really hard.
Old Jun 5, 2007 | 10:29 AM
FWIW, I believe that is due to throwing off your pinion angle and such.
Old Jun 5, 2007 | 03:34 PM
this is true kid
Old Jun 5, 2007 | 04:03 PM
bombebomb's Avatar
I guess it is my mount, car has not flown apart yet. The vibes can get annoying, I notice on hot days its not bad though.
Old Jun 5, 2007 | 07:35 PM
Jared 3870's Avatar
I am using a poly mount and don't have any vibration complaints.
Old Jun 7, 2007 | 12:40 AM
KSSS's Avatar
I just installed mine today. It does vibrate alittle, but mine isnt a daily driver, so i dont really care. I didnt really see that the plate was a seperate piece. I thought it was molded into the poly. I didnt think to take it off.
Old Jun 7, 2007 | 07:09 AM
Capn Pete's Avatar
Another point worth mentioning is that I have a steel driveshaft (as many others do) and they are more prone/famous for vibrating, compared to the aluminum ones which are lighter, and seem to have less balance issues.
And for me, it didn't matter whether I had that extra plate in with the ES mount or not ... it was equally as bad either way .
