Transmission LT1 , LS1
Old Mar 23, 2009 | 04:33 AM
kaunasny's Avatar
Question Transmission LT1 , LS1
Hello all,
I know its engine section but there isn't a trans section anymore for LT1, LS1 .
Is there any difference in the durability of these 2 transmissions? ( M6 )
How much power can they handle stock?
Is it possible to mod these to handle 700rwhp ? What has to be done? ( gears and rear end ) What might be the cost rough estimate? Is it at all possible?
What is the best bang for the buk way to make your f-body trans to handle 700rwhp ?
Thank you for your input
There are many threads for turbo kits and high HP numbers , but I have so much trouble in finding out how durable are LT1 and LS1 transimissions.
Old Mar 23, 2009 | 05:14 AM
Yes, there is a forum.... "Drivetrain". I'll move it there for you.
LS1 has a longer input shaft, and the T/O bearing hydraulic assembly is mounted on the front cover of the trans, concentric with the input shaft. Consequently, it uses a conventional "pusher" type clutch, rather than the lever operated "pullback" design of the LT1.
Old Mar 24, 2009 | 01:44 AM
kaunasny's Avatar
I'm planning to have 550 rwhp on a LS1 camaro, and I might just want to N2O it maybe later on. So I need the transmission to handle that power flawlessly as I plan to go on the strip.
I know T-56 won't nearly handle it. What upgrades or what rear end and clutch would you recommend? or what are my options?
Old Mar 24, 2009 | 08:50 PM
There are upgrades to the T56 that will handle that kind of power. Check out D&D and Keisler
http://www.ddperformance.com/shop/in...p?cPath=107_92
http://www.keislerauto.com/index.php...ed-manual.html
Then there's always "Tranzilla" and "Son of Tranzilla":
http://www.rsgear.com/transzilla.asp
Rear axle assembly choices:
Strange or Moser 12-bolt
Strange 60
Moser 9-inch or M9
Old Mar 25, 2009 | 01:15 AM
kaunasny's Avatar
Thanks alot Injuneer.
rideordie
Nov 5, 2019 04:52 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
