transmission leaking??? *pics*
Old Dec 4, 2007 | 08:03 PM
  #16
sabedra211's Avatar
Alright so i was under the car checking this out. and is this suppose to be movin up and down? if i replace that seal would it fix it?? [IMG][/IMG]
Old Dec 4, 2007 | 09:53 PM
  #17
greenmachinedriver's Avatar
no it sould not move that much. it looks like the tailshaft bearings or output shaft is broken. looks like it might be time to take it to the tranny shop. it does not look like a simple driveway repair. good luck.
Old Dec 4, 2007 | 10:32 PM
  #18
sabedra211's Avatar
ugh really? So do uthink its gona be expenisve???
Old Dec 5, 2007 | 06:58 AM
  #19
93v8clone's Avatar
check to see if ya got any play in the tailshaft of tranny also i have yet to see a seal blow out for noreason leak yeah not alltogether blow out if there is ya got bigger problems than it not movin take it to tranny shop and get wallet ready
Old Dec 5, 2007 | 09:24 PM
  #20
you gotta pay to play.... unfortunately
Old Dec 5, 2007 | 11:30 PM
  #21
Performabuilt's Avatar
Supporting Vendor
Your tail housing bushing has come out, That will result in all that motion, While theres no guarantee there no internal damage from driving it that way . Should vibrated alot! You for now need to replace the tail housing. Or you may try putting in a new bushing but likly the housing is whollered out. The its very possible you will be fine.
Old Dec 6, 2007 | 02:48 AM
  #22
sabedra211's Avatar
How do i replace the tail housing or Put in a new bush? Which is the best? or cheapest way? thanks
Old Dec 6, 2007 | 10:51 AM
  #23
Supporting Vendor
Easiest way would be to replace it you should be able to find one in a salvage yard. You may also likley need a new yoke for your drive shaft that also can be found there, The you remove driveshaft /torque arm and the 4 bolts that hold the tail housig on , Replace old one with new one you will need another oring is the one behind it is not soft, Then just put it all together and cross your fingers . Good luck
Old Dec 6, 2007 | 09:33 PM
  #24
sabedra211's Avatar
Do you think it would be safe 4 the car if i drove it 4 a short distance?
IF it moves? and i put tranny fluid in it?
Old Dec 6, 2007 | 09:50 PM
  #25
My Red 93Z-28's Avatar
I really wouldn't move it until it was fixed...but thats just me.
Old Dec 7, 2007 | 07:12 AM
  #26
If you add fluid, it is just going to sling back out of the tailshaft. Likely, the tailshaft housing is going to have to be replaced. I would not even try to drive it in the current condition, but your transmission may already be so damaged, it does not matter. The black fluid it a very bad sign, as well.
Old Dec 7, 2007 | 07:17 AM
  #27
AL SS590 M6's Avatar
Moderator
NO
You need to fix this now to keep from destroying your trans. It might already be too late but you won't know that 'till you fix the tailshaft.
Old Dec 7, 2007 | 02:58 PM
  #28
sabedra211's Avatar
Alright i wont drive it. But its alright if i try 2 start it up right?
Old Dec 7, 2007 | 05:04 PM
  #29
Supporting Vendor
Agreed do not move the car till you have repaired the tail housing
Old Dec 9, 2007 | 08:57 AM
  #30
12SCNDZ's Avatar
Um...I can tell from your pictures that the tail seal AND the rear seal have already came out of your tail housing. This is most likely due to a few different reasons. One would be severely worn u-joints, or a bad case bushing in the transmission. You'll definitely have to remove the tailhousing to install a new bushing, because you'll want to make sure it fits tight. Keep in mind that simply installing a new bushing and seal won't fix this problem. You'll need to find the cause of the problem.
Frank
CPT
warmeck
Aug 24, 2024 08:05 PM
rideordie
Nov 5, 2019 04:52 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
