Transmission issue... please help
Old Jul 27, 2010 | 07:50 AM
Final03's Avatar
I drove my car fine saturday... Shifted fine and went to drive it sunday and there was no 3rd gear .... When it shifts into third gear it just will rev and not accelerate... Anyone have any ideas if this is a sensor? if so any one every have this problem or any suggestions as to what it might be?
transmission sis a 4L60e automatic transmission by the way.
Thanks for your help...
Old Jul 27, 2010 | 10:44 PM
TD95Z's Avatar
Could be a few things, but when my 96 did this, it turned out the input drum had failed. There is a groove at the edge that retains some of the clutch packs (don't recall which as this was 6 years ago) and the tabs kept shearing off. Not sure if this is a common issue or YOUR issue, but one of the tranny experts will hopefully chime in.
Old Jul 28, 2010 | 08:42 AM
Final03's Avatar
Did you replace this your self or is this a complicated fix if thats the issue?
Old Jul 28, 2010 | 08:24 PM
TD95Z's Avatar
I didn't fix it myself. The tranny was done by a well-known race tranny specialist at the far east of Ohio. He believed my issue was caused by excessive line pressure, but I got rid of the car before I had a chance to investigate that. I was using a Hypertech programmer at the time, and it's possible the increased firmness built into the tranny with the rebuild, combined with the shift firmness improvements of the Hypertech, created a situation with too much line pressure, although I had completely uninstalled the Hypertech tuning after the rebuild. Unless you have specialized tranny tools and knowledge, I wouldn't tackle this job yourself.
Old Jul 28, 2010 | 10:57 PM
Final03's Avatar
I just got my car back from the shop today... Said the transmission is basically junk..
3 of 4 sensors are bad
and most of all the bands are shot and the computer showed slippage in all the gears.
Good news is found another one i can just bolt right up to it..
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
