Transmission grinding
Old Aug 23, 2015 | 10:43 AM
Greg88's Avatar
I was driving my (m6) car the other night and I went to down shift from 6th to 5th, and unfortunately I hit 3rd for a quick second. The car chirped and I quickly hit the clutch and shifted back into 6th. Now I notice (only when I down shift), in mid range RPM the car makes a slight grinding nose and I can feel it in the shifter, but up shifts just fine with no noise. What am I looking at here?
Old Aug 23, 2015 | 04:13 PM
DelSoto's Avatar
Re: Transmission grinding
My guess is that you probably messed up a syncro and or blocker ring.
Old Aug 23, 2015 | 04:45 PM
Greg88's Avatar
hmmmm, seems weird because it only does it down shifting.
Old Aug 23, 2015 | 10:16 PM
TGGodfrey's Avatar
Synchro stop ring for that particular gear. Rest of the synchro is more than likely fine. downshifting you are making the stop ring work a bit harder to bring that lower gear up to speed.
Old Aug 24, 2015 | 07:59 AM
Greg88's Avatar
So is it ok to still drive if I just don't downshift to much?
Formula Steve
Sep 19, 2023 08:31 AM
IndyZman
Oct 22, 2015 02:17 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
