Transmission front pump???
Old Apr 12, 2009 | 06:40 PM
96blackLE2's Avatar
OK well i was just cruisin on the highway doin bout 75 when all of a sudden the rpms jump and the car is like its in nuetral... free revs... I get to the side of the road and have nothin at all... no reverse or drive... it does lock in park tho... It is a stage 2 race trans from speed inc and has maybe 3000miles on it... the trans is a couple years old but the car wasnt driven... When the car sat for long periods tho it would have to be played with at first just to get it to drive... like the pump had to be reprimed or somethin.. i would put it in drive rev it then reverse and so forth til it would drive.... again this was just after long periods of sitting... never any problems with shifting or anything... What do you guys think??? No fluid was leaking nor was it low....
Jeremy
Old Apr 12, 2009 | 11:58 PM
We have a "Drivetrain" forum for questions like this, with quite a few very knowledgable auto tranny folks to help you out. LT1 Based Engine Tech is only for questions about engines.
I'll move your post to Drivetrain.
Old Apr 13, 2009 | 06:09 AM
12SCNDZ's Avatar
This sounds like either the pump or the torque converter.
Frank
CPT
Old Apr 13, 2009 | 06:24 AM
96blackLE2's Avatar
sorry bout putting the thread in the wrong location... Is there anyway i can tell Which of the two is bad?? It is a vigilante 3200 stall.... I heard these are very good converters but just wondering if there was something i could of felt or realized before this happened to know which is bad...
Jeremy
Old Apr 13, 2009 | 11:45 AM
12SCNDZ's Avatar
We've seen many problems with Vig. converters lately.
The best way to diagnose is to to pull your bottom cooler line, at the radiator. Clamp a short length of rubber hose on it, and put the other end in a bucket, or suitable container. Have a friend start the car and see if you've got fluid pumping out of it. Normal cooler flow @ idle is a quart in 20 seconds.
BTW, the speedo isn't going up when the car isn't moving, is it?
Frank
CPt
Old Apr 13, 2009 | 02:24 PM
96blackLE2's Avatar
I didnt notice the speedo going up... not sure if your thinking maybe the rearend broke but it does lock when put into park... I talked to speed inc today and then to the guy who did the trans and he said bring it in and they will check it out... i cant see how if it is the front pump they would want to charge me for the fix... from what i understand and from experience the front pumps are not usually a common problem... ill keep you updated as to what happens...
thanks
Jeremy
Old Apr 13, 2009 | 09:15 PM
camaro81's Avatar
Who installed the transmission into the car?
Old Apr 14, 2009 | 09:46 PM
96blackLE2's Avatar
the place is called DRC and they are in Elk grove village IL... Speed inc uses them for their trans work i guess... we will see what happens im droppin the car off tomorrow
Old Apr 18, 2009 | 07:24 AM
96blackLE2's Avatar
ok well i hate transmissions.... Are they really that hard to rebuild correctly?? I mean if that was my job.... to rebuild transmissions i would hope to be better than these guys.... I pick the car up and he says he test drove it....well first light i come to it almost dies out... then it chugs starting from a stop... converter is locked up... And the stall converter doesnt stall.. maybe it doesnt stall because the converter is locked?? I am so aggravated with this transmission!!! Bout to just buy a GM trans and throw a B&M stall in it... now i have to take it back and see what he says about it now....wtf
Old Apr 18, 2009 | 09:31 AM
12SCNDZ's Avatar
Jeremy, Remember...there are alot iof places out there claiming to be "specialists".
the 4L60E isn't all that mysterious, if you're used to working with them, and you know what they need.
Also, keep something else in mind. A GM reman will have all the same design flaws built back into it that these transmission were plagued with from the start. Besides the fact that we can build you a much better/stroonger transmission for much less than what GM will charge.
As a side note...B&M may not be the way to go for a 4L60E converter.
Frank
CPT
Old Apr 18, 2009 | 10:58 AM
1stooge1's Avatar
CPT What is the turnaround time for a pro-race once you receive it?
Old Apr 18, 2009 | 02:37 PM
12SCNDZ's Avatar
We've been working our butts off to get caught up. We're back to 2 weeks turn-around right now.
Frank
CPT
Old Apr 18, 2009 | 05:19 PM
96blackLE2's Avatar
well this is the 2nd trans place and bout the 5th time its been rebuilt.... The GM trans that i had was fine i just cracked the housing when i broke the trans mount... Other than that a lot of people i know that still have a gm trans seem to be ok.... B&M was just a reference to at least a name brand company rather than just "the trans places converter guy" I went to this place because i got screwed by the last place... Speed inc should have known if this place knew what they were doin before recommending them... Im just aggravated... 2600 twice at two dif places and now 550 more and still no workin transmission... Havent even raced the damn car.....
Magenta_Hearts
Mar 29, 2017 08:54 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
Doug Harden
29
Jul 30, 2003 07:05 AM
