Transmission crossmember
Old May 8, 2006 | 10:21 PM
Honda Hunter's Avatar
What's the difference between the transmission crossmember for the 93-02 A4 and the M6? This is removable correct? Need details on it and can they be removed.
Old May 9, 2006 | 12:21 PM
rngilliland's Avatar
Re: Transmission crossmember
They are a very different shape. Yes it is removable. Four bolts to the frame and a nut on the transmission mount stud.
Old May 9, 2006 | 12:32 PM
can I get away with not having it?
Old May 9, 2006 | 01:18 PM
If you are converting to a T56 you will need the T56 crossmember. I have one for sale in the classifieds. I screwed up and put it under powertrain parts. It has a picture. If you have the auto crossmember you will see the difference.
Old May 9, 2006 | 01:46 PM
I'm not converting. I bought a Global west traction link torque arm bar designed for a M6.
http://para.noid.org/98z/traclink.html
"Globalwest has three Tracklink kits for 4th generation F-body cars. They are for 1993 - 2000 cars with manual transmissions, 1993 - 1997 cars with automatic transmissions, and 1998 - 2000 cars with automatic transmissions."
"The difference between these cars are the the beams. The transmission crossmembers are different between these three types of cars."
i need to overcome this difference so I dont get stuck with this TQ arm.
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
