Transmission
Old Jul 11, 2006 | 12:19 PM
mannycamaro's Avatar
From: San Juan Puerto Rico, Look it up it's in the Caribean
Post Transmission
my car throw all the transmission fluid off ... What could be the problem ???
Old Jul 11, 2006 | 02:38 PM
predator's Avatar
Re: Transmission
well could be front seal,servo cover seal,speed sensor seal,shift lever seal, tailshaft housing seal, rear seal, front pump seal, too much pressure pushing out the vent tube, if it was vacumm modulated it could be burning the fluid, pan seal, gvernor seal if its not electronic, that should sum up the most of it.......maybe you might want to be more specific
Old Jul 11, 2006 | 03:43 PM
"White Knight"'s Avatar
Re: Transmission
What did he just say?^
Old Jul 11, 2006 | 04:00 PM
predator's Avatar
Re: Transmission
i think he may not speak english all that well which is ok but just be a little more specific with the problem...i had a tranny behind a 434 "throw all the fluid off" but the rest of the tranny was throwed all over the place also
Old Jul 11, 2006 | 09:03 PM
Exclamation Re: Transmission
Please forgive my english grammar. But primary language is the spanish. The problem was that I was driving the car and i started smelling something like oil. that made me stop the car and see what was happening. then i realized that the car had trown away ALL the transmission fluid. hope you understand me better.
Old Jul 11, 2006 | 10:11 PM
OBE1 95Z28's Avatar
Re: Transmission
If you lost all your transmission fluid, the car wouldn't move if it's an automatic. If you overfill the tranny, it will pour out the vent tube on the top of the tranny and make a mess. Does the car still move? Have you checked the tranny fluid level on the dipstick (again assuming you have an auto)?
Old Jul 12, 2006 | 12:07 AM
Post Re: Transmission
[QUOTE=OBE1 95Z28]If you lost all your transmission fluid, the car wouldn't move if it's an automatic. If you overfill the tranny, it will pour out the vent tube on the top of the tranny and make a mess. Does the car still move? Have you checked the tranny fluid level on the dipstick (again assuming you have an auto)?[/QUOT
yes, the car moves but, the transmission oil dipstick was empty. the car is an auto. and i didn't overfill the tranny because i haven't put oil in there.
and it's curious that this happened because i haven't abused of the car, i was driving it normally.
Old Jul 12, 2006 | 09:36 AM
OBE1 95Z28's Avatar
Re: Transmission
Predator posted above a pretty complete list of sources for the fluid leak. Best thing to do it crawl under and start looking for the source.
Old Jul 12, 2006 | 10:27 AM
1racerdude's Avatar
Re: Transmission
Could just be a leak in a cooling line or anywhere else that can leak.
Old Jul 12, 2006 | 11:48 AM
1FstFormulaV8's Avatar
Re: Transmission
Could be the front seal. How many miles are on the car? Go look for the leak.
Old Jul 12, 2006 | 01:03 PM
predator's Avatar
Re: Transmission
damn i for got to list cooling lines
check the radiator make sure you dont have tranny fluid inside your coolant
Old Jul 12, 2006 | 03:38 PM
Re: Transmission
I have 103 K on it.
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
