Trans Slipping! A-4
Old Aug 26, 2008 | 09:46 PM
SSHORTT's Avatar
Trans Slipping! A-4
Well i bought the car knowing that it would start slipping once it heated up. "sitting in traffic" ETC... And thats exactly the case, the car runs cold like the thermostat has been removed, but once it heats up after sitting it will start to slip. do you guys think this is maybe a rebuild issue? the car has 192k miles. what are my first steps to getting this problem solved? thanks!
Old Aug 27, 2008 | 09:33 AM
Performabuilt's Avatar
Supporting Vendor
Well I would put a thermostat in and that is solved, As for the trans with 192000 miles is probably just tired and worn , You will need to either rebuild or replace the unit, Please feel free to look at what we have to offer or give us a call
Old Aug 27, 2008 | 11:55 AM
12SCNDZ's Avatar
What condition is your fluid in? Does it appear dark? Is it discolored? Does it smell burnt?
Remember, transmission fluid is like motor oil. It thins as it gets hotter. You may have enough pressure with cold fluid to apply a clutch pack, but as it gets hotter, it may not be capable of it.
Does it slip in everything? The first signs of a cracked forard piston is slipping forward, but reverse is ok. If it slips in everything, you may be looking at a pump issue.
Let me know if I can help you any further. 302-250-1202
Frank
CPT
Campbellb48
Jul 5, 2015 06:31 PM
kmk7110
Jun 20, 2015 05:53 PM
blkWidow
Apr 21, 2015 01:56 PM
jackpawt883
Feb 26, 2015 09:04 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
