Tranny swap please help
Old Nov 24, 2004 | 09:42 AM
bobby patterson's Avatar
Got junk 700r4 in 1992 camaro want t-6 upgrade any help on how & what
would be great. I am body shop mgr of very high class shop i could return favors with info in my field (body related questions)
What car do these come out of
do i need a different bell hsng
speedo will it work
cross member will mine work or will one out of 3rd gen stick car work
Will my drive shaft work.
www.muncie-imports.com
Old Nov 24, 2004 | 11:58 AM
Re: Tranny swap please help
Sorry I Guess It Is Called T-56
Old Nov 24, 2004 | 03:49 PM
crash4cyl's Avatar
Ok you need an LT1 bellhousing T-56. Then give Sphon.net a look. they have a T-56 crossmember as well as a TQ. Arm. You'll also need 84-92 Pedals, and clutch hydraulics. You'll most likely find them in the 305 5 speeds of 6 cyl 5 speeds. Then You'll need to get the a box from Dakota Digital to convert the T-56 VSS to something your 92 can read for the speedo. Aside from that you need to cut a hole in the floor and then use a T-56 shifter and when you get the Pedals see if you can get the plate for the console, so you don't have a gaudy looking console.
Chris
Oh and if you want the Nuetral safety switch to work you need to wire that and the clutch depressed switch for the starter. And don't forget the computer so you get your shift arrows to work....But I think you'll need a new cluster to do that...not sure. I did a little research on it a few years ago and that's what I came up with.
Chris
Cam's maro
Aug 11, 2015 07:45 AM
Collinjacobfowl
Jul 30, 2015 09:35 PM
wesley81
Jul 27, 2015 11:31 AM
Boss002
Jul 24, 2015 10:47 AM
