tranny problem (need help)
Old Jan 19, 2008 | 01:05 AM
94_LT1_camaro's Avatar
I have a 1994 z28 (automatic) , does not want to down shift after a complete stop. already swapped the tranny , does the same thing now. Trouble codes that pop out when scanner hooked up are: (84) 3-2 shift control circuit malfunction.....
i would appreciate any help / tips / opinions
Old Jan 19, 2008 | 05:56 AM
12SCNDZ's Avatar
Was this code present with the old transmission? Did you replace it with a '94 unit?
Frank
CPT
Old Jan 19, 2008 | 03:17 PM
I did not hook up the scanner with the old tranny. I automatically assumed that the tranny did not work anymore , so i had it swapped.
thanks 4 the tips so far if u have anymore please let me know
Old Jan 19, 2008 | 04:56 PM
Performabuilt's Avatar
Supporting Vendor
I would replace the 3-2 solenoid and see what happens. Get the correct one for a 94. The code your getting is and electrical code. Since you dont know if the previous unit had that code thats really the only course of action to start with
Old Jan 20, 2008 | 04:11 AM
Bigrick2324's Avatar
im having same problem so do you guys mean the tranny pan
Old Jan 20, 2008 | 10:18 AM
Supporting Vendor
Yes you drop the pan , I can post a diagram of where the solenoid is if needed. or feel free to give me a call any time,
jmadoll
May 27, 2015 07:13 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
BigWil
Mar 29, 2015 12:24 PM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
