tranny help
Old Sep 24, 2006 | 11:44 PM
outlaw_mike's Avatar
tranny help
im in the process of removing an A4 tranny off a 94 z28, but im having a problem with the top bolts connecting the tranny to the motor, i cant seem to get them loose. for those who have done this before what do you recommend i do.
also does anybody have a link that will help me with the removal of the tranny i dont want to miss anything.
Old Sep 25, 2006 | 09:39 AM
LesPaulGoth's Avatar
Re: tranny help
http://www.zmydust.com/converter.html that might help you out some.
Old Sep 25, 2006 | 01:22 PM
94z2896vette's Avatar
Re: tranny help
what I do to remove them is Go on top where you can access right on top of the engine and reach back to the back toward the trans and use a 14 mm wrench and break them loose . That is what I did and it has always worked for me . Or you can use extenstions and get up there to the top bolts from the bottom of the car you might have to lower your transmission just a lil when you do that . Those are the only real 2 ways I have done it .
Old Sep 25, 2006 | 01:57 PM
Capn Pete's Avatar
Re: tranny help
About ~24" of extension, a swivel socket (preferrably NOT a "universal joint" style) and a bit of muscle. Oh, and a whole lot of patience!!! (I could have used a tad more of that ). A 1/2" ratchet will give you a little more leverage than a 3/8" ratchet.
Also, in my case, those bolts are all a 13mm head, so I used a 1/2" socket (technically "too tight" to go on a 13mm bolt) and hammered it onto the bolts, then it stayed on better while I fought with them!
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
