Tranny Fluid
Old Feb 27, 2008 | 05:31 AM
97silvermaro's Avatar
Tranny Fluid
When reading trans temp through the pcm on a scanner. where is the sensor and how accurate is this? reason for asking is because if the sensor is on the pressure port then it would be reading higher temps
Old Feb 27, 2008 | 10:38 AM
Performabuilt's Avatar
Supporting Vendor
The sensor is in the pan attatched to the valve body temps should be reasonable acurate
Old Feb 27, 2008 | 11:57 AM
could this wire feeding the pcm be spliced into for a temp guage? or is it a completly different kinda sendin unit
Old Feb 27, 2008 | 04:36 PM
The factory schematics show the sensor is a simple thermistor. On that basis, you can't tie another gauge into the ciruit, because it would alter the resistance on the circuit, and the temperature is based on the variable resistance of the sensor.
Old Feb 27, 2008 | 07:39 PM
ahh wouldve been nice and a heck of alot easier to install a guage
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
