Traction Control
Old Aug 20, 2004 | 07:52 PM
z-rated 97's Avatar
Question Traction Control
Was traction control a standard option in 97 for the z28? Is there a switch to deactivate it?
Old Aug 21, 2004 | 12:13 AM
Capn Pete's Avatar
Re: Traction Control
TCS / ASR was never a standard feature.....just an "option". Yes, if the car is equipped with traction control, there will be a switch to turn it off.
Old Aug 22, 2004 | 08:12 AM
2cub49's Avatar
If your car has Traction Control you can get a module for 50.00 from SLP or Thunder Racing that will reverse it.
That way it will be normally off when you start the car and you have to turn it on.
I hated having to turn it off every time I started the car and haven't used it at all since I put in the module.
Old Aug 22, 2004 | 09:42 AM
LT1 PWRD's Avatar
The traction control system on my car saved my *** a couple times driving in the rain. I have to say that this system works very well.
I never bothered getting that switch to reverse it but I do turn it off most of the time.
I utilizes the same wheel sensor as your abs system and when the sensor goes, so does your traction control.
Old Aug 22, 2004 | 09:46 AM
zachattack45's Avatar
Where is the switch to turn it off?
Old Aug 22, 2004 | 11:05 AM
Dave '97 Z28 M6's Avatar
On the dash, above your radio and beside the fog light switch.
Old Aug 22, 2004 | 11:07 AM
I have a 95 trans am, is it in the same spot?
Old Aug 22, 2004 | 07:33 PM
95 WHITE TRANS's Avatar
On the TA it's located on the gear console right before the arm rest.
NICK
Old Aug 22, 2004 | 07:53 PM
2cub49's Avatar
The reverse module only works on 97 and up cars.
I think I turned mine on once or twice when it was raining really hard.
I have driven my car in the winter and may again this year. The Traction Control makes getting the car going more dangerous IMO. With 4 snow tires and sandbags in the trunk my car tracks pretty good in the snow.
However you have to spin the wheels to get into traffic often enough and it can leave you a sitting duck for being hit when it kicks your foot off the pedal and you lose time disengaging it so you can go.
Once going on a snowy or rainy road it's ok.
Old Aug 22, 2004 | 08:13 PM
Im not seeing it, i have an M6, does that change anythign?
Old Aug 22, 2004 | 10:13 PM
Capn Pete's Avatar
If you can't find the switch, then obviously you don't have it! (be glad!)
2cub49, I hear what you're saying about driving in the snow.....I've driven mine for the past 2 winters with no (or very few) problems. While YES it's a b!tch to get moving initially, you do need to get the wheels moving, and it does take a balance of spinning and letting off the gas, but as long as you know how to control the car, then there's no problem. Truthfully, I feel like my car stops and steers better than anything I've ever driven in the winter!
Old Aug 22, 2004 | 11:34 PM
Sorry for the confusion - I just ASSuMEd you had a Z28.
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
drt
Sep 27, 2015 04:39 PM
