Tourqe Arm / Noise
Old Jul 10, 2006 | 08:57 PM
  #16
snakeatinZ's Avatar
Re: Tourqe Arm / Noise
My little brother's 95 formie, with around 430 rwhp, just broke its second stock torque arm. We are looking for something to stand up to this power leaving the line at around 3000 rpm's. We were looking at this exact torque arm but it doesn't sound very safe. The car has long tubes and a dump out of the y pipe so that extra road noise doesn't scare me. But, I am very concerned about the clunking and the car darting all over the place when you get off the gas. Please suggest something reliable.
Thanks!
Old Jul 10, 2006 | 11:19 PM
  #17
I use the Spohn TA at 600+ rwHP, and the car is as stable as it could possibly be... no wandering or darting. I've seen the same Spohn TA (with one extra diagonal brace) take a 3,525# 30th SS convertible to 8.50@160+MPH, with a 1.30 60-ft. It will take anything you can throw at it.
Old Jul 11, 2006 | 01:30 AM
  #18
quickmedic1's Avatar
Is your bar noisey too? Mine is noisey enough I think I may remove and sell it.
Old Jul 11, 2006 | 05:48 AM
  #19
snakeatinZ's Avatar
Do you have clunking when you shift? Tunnel mount? Tranny mount? Price? Where to buy?
Thanks,
Steve
Old Jul 11, 2006 | 05:49 AM
  #20
snakeatinZ's Avatar
Clunking when shifting? Or road noise?
Old Jul 11, 2006 | 07:58 AM
  #21
z96's Avatar
z96
my noise happens on hard acell feels like a broken trans mount this is deff not normal very hard slam knock noise. umi wants me to retourqe all connections for my three point subframe connectors. also check tourqe on on tourqe arm bar bolts then go to pinion angle. then call them back.
poss my springs are saging car only has 47,000 miles or maybe previous owner lowered car?? bar comes set for stock ride height.
does anybody now of a good suspension shop close to bx ny
Old Jul 11, 2006 | 08:02 AM
  #22
You can hear the gear lash when you put it in gear, or shift to reverse. But under normal driving, I don't notice anything severe in the way of noise. But the entire rear suspension is rod ends, including the TA, LCA's, Spohn race version sway bar and the panhard rod. Any noise is sort of covered up by the sound of the dual 3" pipes and Borla shorty mufflers dumping in front of the rear axle.
I have the Spohn chassis mount torque arm, with the rod end, and a driveshaft loop. All of my Spohn parts come directly from Spohn and Steve Spohn installed most of them, often as a test install, and to get some photos of the installed parts and to develop install instructions. It uses an older style dropped front mount, because I used to run a 4" Mufflex.
When the car was a daily driver, I used the poly front mount on the torque arm, and that helped keep the noise down. But noise that comes from properly functioning performance parts doesn't bother me.
http://www.injuneer.com/images/photo.../DCP03675a.jpg
http://www.injuneer.com/images/photo.../DCP04302a.jpg
Old Jul 11, 2006 | 08:54 AM
  #23
NOSCaMaRo's Avatar
Thanks!
The torque arm is not causing the darting, that has to be something else suspension related. I run the same tunnel mounted arm with no issues like that and I have never heard of this either. Like Ijunineer has said, it is either Panhard bar, bushings or could even be shocks. It sounds like the problem is being blamed on the last item that was installed when it return it has to be something else I would be sure.
As for the clunking, that is the pivot point. That torque arm is designed to pivot during accel and decel. If the bolts are not torgued correctly or over torqued it may take more force to less force to move them causing a noise or clunk. It is not unsafe like you think, it is pretty normal with this set-up
Old Jul 13, 2006 | 07:52 AM
  #24
madman69's Avatar
The darting is most likely coming from the Detroit locker locking and unlocking.
Old Jul 13, 2006 | 02:40 PM
  #25
I've also found that on the street, with my 315 BFG Drag Radials, if there are any ruts in the road surface at all - and NJ asphalt roads ALL have grooves from the 18-wheeler tires - the back end will dart a bit as the edges of the tires move in the grooves. There's always a little bit of irregular motion, even driving under low load because of the wide tires. But put it under full throttle, full torque and the tires dance all over in the grooves.
At the track, with 28" slicks, it becomes a non-issue.... launches straight and stays straight all the way down the track.
Old Jul 13, 2006 | 04:00 PM
  #26
z96's Avatar
z96
Injuneer how far do you live in nj. i live in the bronx i whish you could hear my problem and know its not normal. sat i putting it up on a drive on lift then ill let every body know
Old Jul 17, 2006 | 03:30 PM
  #27
z96's Avatar
z96
just wanted to give an update check under car found on drive on lift found my umi brkt that bolts to rear hitting body performed pinion angle check found way out. i guess my car is poss lowered. i am second owner. i adjusted tourqe arm to -3 as per umi instructions. now noise in totaly gone no noise what so ever. thanks jerry from umi for instruction on how to fix. sorry about bashing your company
Old Jul 17, 2006 | 09:49 PM
  #28
UMI Performance's Avatar
Former Vendor
No problem at all, I am just glad you got it working correctly. The tunnel mounted torque arms can be tricky to set-up at times. I will be sure to tell Jerry you got it fixed and taken care of, he was asking me today if I have heard back from you yet.
Thanks again!
Ryan
Quickss96
Jan 29, 2016 05:56 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
Jul 7, 2015 07:19 PM
