Tourqe Arm / Noise
Old Jul 6, 2006 | 08:49 AM
z96's Avatar
z96
Tourqe Arm / Noise
I Installed A Umi Performace Tourqe Arm Now I Have A Bang Noise On Acell And From Reverse To Foward. Also Car Feels Like All Over Road. Is It Poss Tourqe Are Is Making Suspension Feel Like This And Making This Noise. Thanks In Advance For All Help.
Old Jul 6, 2006 | 08:57 AM
Re: Tourqe Arm / Noise
Tranny mount design or chassis mount design? If chassis mount, what type front connector - poly bushing or rod end? Fixed or adjustable pinion angle? In a 96? What kind of power are you making? Have you checked the tranny mount?
Old Jul 6, 2006 | 09:29 AM
z96's Avatar
z96
Ok It Has Poly Bushings. Hook To Under Body Not Trans . Adjustable Ends For Pinion Angle. 383 Was Built For Super Charger. But Not Installed Yet . Not Sure Of Power Low Compression Engine 8.5-1 Is 1996 Z28
Old Jul 6, 2006 | 09:38 AM
z96's Avatar
z96
Also Have Poly Engine Mounts But A Stock Mount. I Tried To Install The Poly Mount But Its A 1/2 Taller Then Stock And Pushes My Headers To My Floor Boards.
Old Jul 6, 2006 | 09:39 AM
user 647483's Avatar
Have you checked the trans mount?
Old Jul 6, 2006 | 09:41 AM
z96's Avatar
z96
dont seem broken when i push up on tailshaft
Old Jul 6, 2006 | 09:43 AM
z96's Avatar
z96
also suspension of car feels like all over road after i get off gas.
Old Jul 6, 2006 | 07:46 PM
smokytires's Avatar
I am having the same problem, I have the UMI adjustable tunnel mount TA,
9" strange w/ detroit locker. My car darts over to the side of the road when I tap the gas and does the same when down shifting or letting of the gas.
Does any body have any ideas
Old Jul 7, 2006 | 10:14 AM
z96's Avatar
z96
Ttt
Old Jul 8, 2006 | 11:36 AM
LiT1_up's Avatar
I had a forward and reverse clunking with my BMR ta also. Make sure you get the bolts on the front of the ta good and tight, especially the bottom one. That took care of the issue I had with it.
Old Jul 10, 2006 | 08:17 AM
z96's Avatar
z96
Ttt
Just To Let Everybody Know If You By Umi Products From A Vender Donot Expect To Get Any Help From Umi. From Now On I Will Not Tell Anybody Anything Good About This Company. I Was Told To Call Vender Who I Purchesed It From.
Old Jul 10, 2006 | 12:52 PM
UMI Performance's Avatar
Former Vendor
Z96- Marlena took your message last week concering your problem. The message says you have already tried some tips per our advice. This means at one time we have talked to you about it. If Marlena feels the order is a vendor issue she does tell you to call the vendor since they made the sell. Since she doesnt build the parts or install them sometimes she does not know so she does suggest that.
As for not calling you back, I as well as my tech support have been attending the Thunder in the North show since Thursday and we have been out of the office. We have just returned to the office this morning. We are going threw messages today and we will return your call today.
On a side note on the noise, some noise can be expected when installing a set-up like this. We should be able to pin point and take care of most of it. But depending on how sensitive you are and your set-up you may notice some increase in road noise
Thanks,
Ryan
Old Jul 10, 2006 | 02:56 PM
z96's Avatar
z96
Update Umi Did Call Me Today Gave Me More Tips Which I Will Try Sat On A Drive On Lift. Thank Jerry For Calling Me Back Will Be Intouch Again Next Week.
Old Jul 10, 2006 | 04:40 PM
Suggestion.... turn of your "caps" lock. That's why your posts come out with a capital letter at the beginning of every word.
A torque arm mounted to the chassis is inherently noisy. You can pretty much expect the pinion lash to be audible when you put it in gear or in reverse. Its the nature of the beast.
But if the back end of the car seems to wander and dart all over the place, you have some sort of problem. Wandering would more likely be tied to the panhard rod. Have you checked the panhard rod bushings to make sure they are not worn out?
Old Jul 10, 2006 | 04:48 PM
joe-96z1le's Avatar
What suggestions did UMI offer?
