Torque and Differential HELP!!!
Old May 6, 2005 | 09:45 AM
corvettez28's Avatar
Cool Torque and Differential HELP!!!
I am new to tunning and I was wondering what would be a good stall converter for a 4L60E. How or where would i have 4:10 gears installed? Im not really sure about me rear end so i have no idea if they will fit.Can some one help me?
95 z28
Old May 6, 2005 | 09:50 AM
teke184's Avatar
Re: Torque and Differential HELP!!!
as long as you get the correct ring diameter, 7.5" 10bolt and the proper carrier (2 or 3 series) they will fit just fine.
you'll have to call around to find a shop that will do the install.
and most people will tell you that 4.10s in an auto are too much, try 3.73s.
for good results try a stall in the 3000+ range
realize you'll need a reprogram for your ecm to run the gears
Old May 6, 2005 | 09:59 AM
Thanks man i appreciate the info. Would you advice me to change the trans on my car to something like a raptor transmission or just modify the one i have? Im going to a LT4 corvette conversion i have the engine installed. Again thanks
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Henson071
Sep 18, 2015 04:01 PM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
