Torque arm install tips
Old May 25, 2013 | 05:40 PM
KYWes's Avatar
Ok, i'm trying to get the torque arm back on my 95 Z28 Convertible and I'm having problems. I've got a jack under the rear end to tilt it down but I can't seem to tilt it enough to slip the torque arm on to get the bolts in.
Any tips?
Old May 25, 2013 | 07:55 PM
Re: Torque arm install tips
Open the front bushing clamp and take the TA out of it. Mount the rear of the TA on the rear axle assembly. Then pull the front of the TA down and fit it in the front bushing clamp.
Old May 25, 2013 | 08:19 PM
KYWes's Avatar
Thanks for the tip. The TA is not mounted in the bushing. It is completely loose now. I've not been able to get the TA over the mounts on the differential even though I have put a jack under the diff and tilted it. I can't get the front of the TA high enough in the transmission tunnel to line the TA up with the diff.
I've seen a post that said to undo the shocks and springs but I've not had to do that before. I feel like I'm missing some trick as I removed and installed the TA a few times before.
Thanks again.
Old May 25, 2013 | 10:32 PM
z28ke's Avatar
You shouldn't have to unbolt the shocks. Try to figure out a way to pry the front of the rear end down, but you can usually get it by jacking up the rear as you stated.
Old May 26, 2013 | 10:32 AM
KYWes's Avatar
Thanks for the reply. I thought I was doing it right. I'll start back on it today and figure a way to get it on.
Old May 29, 2013 | 12:56 PM
KYWes's Avatar
Got r done. Just had to hold my mouth right I guess.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
