tightening drive train bolts - how tight??
Old Dec 15, 2003 | 02:04 PM
menlatin's Avatar
So, we've been having some problems with keeping the drive train stragiht with the rear-end. I think my frame is bent, but i dont have the money to get that fixed. SO, we used a "come-along" and pulled the trannie and motor straight. I've got ALL grade 8 bolts, and so far, have torqued the motor bracket bolts to 40lbs, the trans corssmember bolts to 35 lbs, the trans mount (poly) to crossmember bolts to 35lbs, and the tans mount to trans bolts to tight as f*&@ since i can't get a torque wrench up there. YOu think that is enough pressure on everything, or can i do it tighter since they are grade 8.
this is in the 72 truck.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
dmaastr
9
Jul 1, 2002 02:22 PM
