ls1 t56 to lt1
Old Dec 11, 2003 | 09:58 PM
lunatic515's Avatar
ls1 t56 to lt1
has anyone ever put a 98 newer t56 into a car with a lt1. I already have the transmission and it was cheap enough, so ill find a way to do it. Any help on what might need to be done will be appreciated.
Old Dec 13, 2003 | 06:55 AM
Black6SpdTA's Avatar
The bellhousing bolt pattern and input shaft are different. I don't really know the specifics of it though.
Old Dec 13, 2003 | 10:29 AM
95patriotZ's Avatar
I also belive the way the slave cylinder in internal or something. I am not sure but I also looked into this when I started my six speed swap and somebody told me the slaves are different.
Old Dec 13, 2003 | 12:08 PM
If that was the case, you could probably retain the LS1 lines just plumb them to the correct LT1 slave.
I think you can also swap input shafts, although I imagine it's pricey. I don't think anyone makes a conversion bellhouisng though. I read about Centerforce might make one soon.
Another thing, the clutchs are different, I wonder if that will make any difference, such as the 98+ flywheel bolting to the older block.
lunatic515: If you got it for real cheap, look into it some more, I'd be interested to hear how everything goes.
-Rippin
Old Dec 13, 2003 | 08:20 PM
lunatic515's Avatar
The bellhousing bolted right up, just has one bolt hole missing. The input shaft is too long, so i think i can just make a spacer to put the input shaft in the right spot. As far as the clutch goes, i will have to use the ls1 clutch for the right height and i found out that the flywheel has a slightly different pattern, but i can use a flywheel from a factory lt1. the lt1 and ls1 master cylinder are the same, but the slaves are different, the ls1 is a push style while the lt1 is pull. I want to keep the push style. I just wanted to know if anyone has done it so i could save some time in trial and error. thanks guys
Old Dec 15, 2003 | 08:46 PM
SwagonS's Avatar
Check out the http://www.bigfastcar.com/overview.asp
BTW: what year is the LT1 in? I'm looking for info on dropping one in a '72.
Sergio
Jan 27, 2016 04:27 PM
Jason Short
Jan 19, 2015 06:34 PM
InfernalVortex
Jan 17, 2015 09:35 AM
